which Honda ATF do I need for M6 dealer says type for auto or for manual trans
Old Aug 3, 2003 | 01:33 AM
D James's Avatar
They seem to have two different kinds, from what I've searched I neeed Honda ATF Z1, well the dealer asked If I needed the auto brand or the manual trans brand. I thought or cars take the auto trans stuff, but am really unsure. Which is it
Old Aug 3, 2003 | 01:37 AM
Mikey97Z's Avatar
GM Syncromesh Dexron III you can get a gallon jug from your local GM dealer.
Old Aug 3, 2003 | 02:13 AM
Carlos01SS's Avatar
Re: which Honda ATF do I need for M6 dealer says type for auto or for manual trans
Honda Automatic ATF. Our M-6's love it.
Old Aug 3, 2003 | 11:46 AM
94 CAMRO Z28's Avatar
Doesn't ATF stand for Automatice Transmission Fluid?
Aaron
Old Aug 3, 2003 | 12:11 PM
TA Dreaming's Avatar
yes atf is automatic trans fluid. our M6s use ATF not gear oil. ive never heard of using honda ATF though. why would you want to use that? thanks. Trey
Old Aug 3, 2003 | 12:43 PM
Hyperspeed97z28's Avatar
honda atf z1, just use any atf, the difference isnt that much, i use it now but i am gonna switch it monday with the clutch swap....
Old Aug 3, 2003 | 01:12 PM
gb95zconv's Avatar
The honda stuff is good....but my tranny is quieter with the Mobil 1 ATF for the same price.
Old Aug 3, 2003 | 02:39 PM
turbo_Z's Avatar
I switched to that Honda ATF trying to solve grinding on light shifts in the cold winter months and I have to say it is good stuff. The damned grinding didnt really go away but when the tranny warmed up the shifts were nice and smooth. Now, just a few weeks ago I replaced my clutch and went with the Mobil 1 ATF b/c it was easy to find where the Honda stuff must be bought at a Honda dealer. Anyway after switching to the Mobil 1 I have noticed no change between it and the Honda ATF... results my vary but in my case any higher priced synthetic ATF will likely do the trick.
Old Aug 3, 2003 | 02:53 PM
im gonna step down from the honda atf z1 to regular mobil or max life atf
Old Aug 3, 2003 | 03:58 PM
jasons93z's Avatar
Ive had good luck with the Max-life Atf.
Old Aug 4, 2003 | 01:39 AM
D James's Avatar
I was thinking about going with the Mobil synthetic stuff, but I thought I read somewhere that synth was bad for our trans, something to do with the syncros or something. I don't know squawt about this trans so If anyone has heard this I'd like to know. I'd like the mobil instead since the honda dealer is real far away when I could go and get the other stuff in one minute
Old Aug 4, 2003 | 01:09 PM
gb95zconv's Avatar
Try some of the GM rear addative...if its syncro noise(whine) it will quiten it considerably....it will take a couple of bottles. If its real grinding as you say it want help.
Old Aug 4, 2003 | 01:13 PM
gb95zconv's Avatar
Never seen solid proof of this.....urban myth IMO.
Old Aug 4, 2003 | 02:21 PM
tranny fluid is tranny fluid, dex 3 for us guys, Id say if you change it often ex maybe 25k then use the cheap stuff, pennsoil or whatever right ??
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Moshbmx1
Feb 17, 2015 10:51 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
Lederman1976
Nov 30, 2014 05:21 AM
