homw much timing chain slack?
Old Jan 20, 2008 | 04:55 PM
97SS0594's Avatar
ive searched but found no specific measurement, all ive read is "there tends to be alot" but define alot? i installed my low low milage timing set (i put 300 miles on it and the lower end took a poo) and theres a ton of slack. we then tried the set off my 95 and there was the same amount of slack. it moves about 1/4 inch maybe a little more back and forth.
Old Jan 20, 2008 | 05:23 PM
'94 Bad A Z28's Avatar
Ummm... none. My timing chain with 120K on it had no slack when I did my heads/cam. Reused it for another 10K pulled it out and it still had no slack.
Old Jan 20, 2008 | 05:33 PM
Stl94LT1's Avatar
That's about how the stock chain in my 94 looked at 15k miles.
Old Jan 20, 2008 | 05:34 PM
Stl94LT1's Avatar
No slack? That's rare, very rare.
Old Jan 20, 2008 | 07:04 PM
Dunno, guess I just got lucky, my chain now doesn't have any slack either.
Old Jan 21, 2008 | 02:24 PM
sn8ke eatr's Avatar
at 180k miles mine had alot of slack. i replaced it with a chain which had like 80k on it.. it had almost as much slack as the original one
Old Jan 21, 2008 | 02:59 PM
user 647483's Avatar
Mine was pretty stretched at <50K, we replaced it as part of the H/C install.
Nice it tight now
Old Jan 21, 2008 | 03:24 PM
z28_theantirice's Avatar
mine with 55k on it had a decent about of slack, I would say its normal. With only 300 miles on it I would resuse it...
Old Jan 21, 2008 | 06:14 PM
97SS0594's Avatar
iwe have the low milage set on it now, we will see what happens! i have faith i did find a penny heads up and it was from 97 so i think thats a good omen right?
Old Jan 21, 2008 | 09:32 PM
LearJet's Avatar
Loose LT1 timing chains is a common thing, if you get lucky and yours is not loose good for you. If yours is loose and it bothers you get one of these: http://www.thunderracing.com/catalog...vid=4&pcid=222
Read that whole page and you will see what I mean.
Old Jan 22, 2008 | 12:01 PM
JeremyNYR's Avatar
wouldn't an oversized crank sprocket (as they suggest in that link) throw off the gear ratio between the cam and crank sprockets? The only way I can see it not affecting the ratio is if they somehow increased the diameter yet maintained the same number of teeth as stock and are still able to smoothly engage the teeth with the chain.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
