Homemade CAI Help
Homemade CAI Help
Anyone here ever make a homemade CAI setup with some PVC pipe? A kid I know did it, but I was wondering if any of you ever made one for an LT1 and how many/what size pipe/ how much pipe.... would you use to do this. I heard it works better or as good as the SLP setup.
first thing i did with my car was make a sewer pipe CAI ..
i used 4" PVC .. but if i had to do it again i'd do it with 3" to fit the MAF properly and not have to mess with the ABS unit
just put 2 bends in it .. a 4"x9" conical K&N sitting parrallel to the ground ...
u can kinda see my ugly one here
http://www.sfu.ca/~pkavousi/cruise/IMG_0890.JPG
I used some of that gray colored pvc electrical conduit, its a 3 1/2 OD. I cut about a 3rd of it off and mounted it with the k/n filter behind the headlight assembly. I fab'd a heatshield to isolated it from the engine, and a airdam underneath to direct air to it. I did have it rigged up with the filter in the bottom but I wanted it where it was easy access for filter inspection. The car still feels as fast as it was before to me
go to jegs or summit or jcwhitney and get a 90* mandrel bent pipe (3 or 4 inch), and buy the biggest K&N filter you can find that will fit. Then go to HomeDepot and get a PVC pipe rubber coupler to attach it to your MAF. If you paint it black, I swear that it will look as good as any kit out there, and it will work just as well.
$20 pipe
$35 filter
$8 coupler
Total = $63
I'll try to get some pics of the one I made.
$20 pipe
$35 filter
$8 coupler
Total = $63
tdigger9899
Sep 7, 2015 10:56 AM
