Hissing sound from under the hood. Sounds like vaccuum leak?
Old Jun 14, 2004 | 12:25 PM
PlaneCrazy's Avatar
Anyone know what this could be? A loud continous hissing sound coming from under the hood. I can't really pinpoint, but it sounds like it's coming from around the area circled below.
The engine is acting normal, just this noise. Sounds like a vaccuum line has been cut, and it's sucking air in... Although wouldn't that make the engine run like crap?
Any ideas? Thanks for any and all help!
Jeff
Old Jun 14, 2004 | 12:51 PM
MEAN LT1's Avatar
Re: Hissing sound from under the hood. Sounds like vaccuum leak?
Jeff
When its at an idel does the motor flare liek go up and down continuously(sp)?.
Old Jun 14, 2004 | 01:04 PM
PlaneCrazy's Avatar
No, it idles pretty smooth..
Old Jun 14, 2004 | 01:17 PM
tagz's Avatar
going out on a limb here.... but check the elbow. They always get folded under and you don't even realize it. Mine did that once and the car idled perfect. The only time i noticed a problem was when i hit the gas. It would hesitate then go.
Just a thought :-\
Old Jun 14, 2004 | 01:34 PM
n2ceptor's Avatar
Check elbow....
MAP sensor is right on top, rubber gommet might be torn/worn...
Also, EGR sensor is in that location, has vacuum lines
Magenta_Hearts
Mar 22, 2015 03:36 PM
NewsBot
Mar 19, 2015 12:20 PM
fpete1992
Dec 11, 2014 03:51 PM
CamaroZBoy
Aug 16, 2002 10:03 PM
teedoff59
Aug 8, 2002 01:36 AM
