Highest lift cam with short valve covers.
Old Jun 26, 2007 | 07:14 AM
  #16
96vortechSS's Avatar
Originally Posted by rskrause
We have an HR cam in my friends SC Mustang that turns 7,5000rpm no problem.
Rich
Wow!
Old Jun 26, 2007 | 11:31 AM
  #17
HardcoreRM125's Avatar
Whats the limit on the stock PCM, 7200 right ???
Old Jun 26, 2007 | 04:31 PM
  #18
Somewhere around there I think. I think that is where Rick Abare was running into problems with it. I'm running F.A.S.T. though.
Old Jun 27, 2007 | 12:43 AM
  #19
OoOo, FAST can make high RPM stuff more doable ...
Old Jun 27, 2007 | 03:27 AM
  #20
SS RRR's Avatar
Originally Posted by 96vortechSS
Due to my turbo manifolds I have to run short valve covers. My heads flow 317cfm at .700 lift and heads are setup with .650 lift springs. I'd like to run the highest lift I can possibly run with short valve covers. One cam I'm looking at is .630 lift with 1.5 rocker arms. The other is .619 lift with 1.6 rocker arm. I'm thinking if I run a larger cam an shorter ratio rocker arm I can get away with more lift. Is that right?
I am running a cam with .650 lift, 1.6 Crane Golds using LT4 composite valve covers. After spinning the engine several times there is no interference.
Old Jun 27, 2007 | 06:01 AM
  #21
That is good to know.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Decromin
Aug 18, 2002 10:11 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
