Higher rpm sputter/bog?
Old Jun 10, 2006 | 02:46 PM
Camaro350z28's Avatar
I've been having problems with my 97z for awhile now. Can never get it to run good at the track cause it always seems to miss at higher rpms... at first i figured opti, and tune up. Did everything brand new does the exact same thing. The thing is it only seems to miss under full throttle. Its not exactly a miss but kinda miss/bog kinda thing. And now ive recently noticed my check engine light does not work.. and i high a driver side cat converter code.. can a clogged cat possibly be my culprit the whole time?
If so.. i need to find a used one.. brand new cat a little expensive and my headers bolt directly to the cat..
93 RedBird
Nov 15, 2015 08:24 AM
95chwagon
Oct 16, 2015 12:24 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
