high speed fan wire, blue or green?
Old Jul 8, 2003 | 08:35 PM
brandboZ28's Avatar
I did a search and couldnt find which one was the high speed wire. I am doing a manual fan switch and just wanna run the high fan instead of having a switch to toggle between the low and high fan. Any help would be greatly appreciated. Thanks!
Bo
Old Jul 9, 2003 | 01:03 AM
fbird95's Avatar
If i remember correctly blue was the high speed wire. But i'm not 100 % sure, I do know that shoebox would definatly know for certain. Just ground each one from the fuse block under neth the hood. Which ever one triggers the high fan is the winner.
Old Jul 9, 2003 | 04:21 AM
Mtrhds94Z's Avatar
Hi and low fan speeds didn't start til late 94 and also have 3 relays for fans..
Early 94 [not positive about 93?] have primary and secondary single speed fans... 2 relays only..
Old Jul 9, 2003 | 07:25 AM
importeater's Avatar
Yep, Blue it is.
Old Jul 9, 2003 | 07:29 AM
If you want both fans to run, you must ground both blue and green. On a 1993 there is one relay for each fan and they run at high speed when they are turned on.
Old Jul 9, 2003 | 04:24 PM
brandboZ28's Avatar
Thanks guys
Feffman
Oct 9, 2015 05:42 AM
Jan 23, 2015 01:13 PM
ChrisFrez
Dec 15, 2014 03:09 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
