High rpm miss under load
Old Oct 12, 2003 | 02:45 AM
  #16
White96Z's Avatar
An ICM is the Ignition Control Module. Usually an ICM problem is associated with heat. However, it could be your problem.
Old Oct 13, 2003 | 08:16 PM
  #17
scoobysnax83's Avatar
Very True
Old Oct 13, 2003 | 09:34 PM
  #18
Wicked's Avatar
If it's the ICM, would it work like this. While cold get miss at 6800.. if hot does it at 6200? Is that possible?
Thanks,
Jason
Old Oct 14, 2003 | 01:22 PM
  #19
White96Z's Avatar
Usually, if you have an ICM problem, as the operating temperature goes up the problem becomes worse. From what you've said I would say you very well could have a problem with the ICM, but don't rule out something else.
Old Oct 14, 2003 | 08:34 PM
  #20
Wicked's Avatar
I'll test it with my friends on Friday, I'm also gonna check my vacum tubes. Someone else posted that could be a problem and I know those are messed up.
My ICM has 110k miles on it, so really wouldn't suprise me and maybe I'll just change it for good measures.
Thanks,
Jason
Old Oct 14, 2003 | 09:36 PM
  #21
They aren't to terribly expensive. And it won't hurt your problem
Good Luck
Old Oct 14, 2003 | 09:52 PM
  #22
96z's Avatar
96z
From what Ive always been told ICM's are either good or bad. They dont slowly die on you...
Old Oct 14, 2003 | 10:37 PM
  #23
94GrayV6's Avatar
I agree with 96z. When mine went the car was running fine then all of a sudden just died while going down the highway. Wouldnt fire back up.
edman
Mar 13, 2015 09:39 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
DetroitZ28
Feb 13, 2015 07:33 AM
edman
Jan 22, 2015 02:45 PM
