high rpm hesitation stumble
Old Feb 11, 2004 | 02:03 PM
sabre81's Avatar
lately i noticed when i mash the gas from a stoplight i get to about the rev limiter and the car starts to hesitate and stuble then a second or two and it continues fine. Now this doesnt happen when crusing. if i mash the gas at say 40 it goes fine.
i have a brand new fuel filter in there.
103000 miles
plugs and wires havent been changed
o2's havent.
Old Feb 11, 2004 | 02:09 PM
Fastbird93's Avatar
High RPM breaking up is a very common opti symptom. Are you on the original, or if not how old is the one in there?? How old are the plugs and wires also?
sabre81's Avatar
i would say original everything. there is a slight hesitation at low rpms if i were to rev then engine, everything seems to be better the car is NOT cold
Old Feb 11, 2004 | 03:34 PM
scoobysnax83's Avatar
actually I believe almost redline break up is usually coil and midrange break up is opti...
Old Feb 11, 2004 | 03:53 PM
viper3885's Avatar
yea i'm having the same problem, around 4.5k to redline it'll stumble and feel like you hit rev limiter and also if i rev to hard from idle it'll stumble then rev... unless it's at 1k or higher then it'll rev fine. also my car won't start when wet out. i had new wires, cap and rotor put on and it ran fine for awhile but now it started to act up again, but now it's kind of a hit and miss with it stumbling at full throttle in the higher rpms. i really need to figure out which part it is before i go replacing things seeing as i lack $$$. i've been thinking it has something to do with the ignition coil or the ICM.
Old Feb 11, 2004 | 04:00 PM
If you haven't replaced the entire opti, then that is "your" problem...
Old Feb 11, 2004 | 04:09 PM
1995greenTA's Avatar
hey guys i have the same problem except mine is from 4.5K to redline, and when you mash it anywhere under a bout 2000 it stumbles! im running 87 octane gas, at the moment and the problem is not as noticeable with higher octane, but is still there. the fuel pump/filter/fuelpressure regulater, opti and waterpump have all been changed resently, its a 95 M6 with 61,xxx on it, original wires though. any ideas?
Old Feb 11, 2004 | 04:18 PM
now I know where thread hijackers anonymous meets....
Old Feb 11, 2004 | 04:35 PM
viper3885's Avatar
well in your post above you said that almost redline breakup might be a coil problem, thats the only time my car backfires. and also when i first got the car back the little stumble if i revved at idle was non existant no matter how much throttle i applied then about a day later the little stumble came back and about a week or two later the high rpm backfiring came back and it wouldnt start again if it was wet out. sorry don't mean to be a pain in the ***, i'm just trying to get a better idea of what the problem is before i go dropping another huge *** load of cash into the car after spending 900+ for a tune up.
EDIT: oh yea, i didn't mean to hijack the thread by any means. i just figured that since this thread already exsisted that i'd ask in here instead of making my own thread. plus everyone would prolly tell me to do a search. so... sorry no intent to hijack, just to learn
Old Feb 11, 2004 | 05:01 PM
I consider 4.5k rpm at the middle to top of midrange. Redline is 6k or so rpm, 6200 I believe is the rev limiter. Let me put it this way. From experience if you have break up at a certain rpm all the way to redline than I blame the coil. The reason being that the coil's ability is being maxed out therefore how can a coil perform better at a higher rpm than where it breaks up?
And, If you have any break up below that, but only at a certain rpm or range of rpm than I blame the opti.
And... Now the Simpsons are on, so I will be gone till 7... I thank you
Old Feb 11, 2004 | 05:11 PM
viper3885's Avatar
aright thanks for your help, i guess i'll have to drop it off at the mechanic's next time it's supposed to rain so they can figure it out
Fastbird93's Avatar
I believe that the LT1 rev limiter is somewhere around 5750 give or take. You may be thinking LS1 when you said 6200 was the limiter.
Old Feb 11, 2004 | 05:13 PM
Fastbird93's Avatar
No need for that yet. It wouldn't hurt to grab a new coil plugs and wires to do yourself. If the move to the opti comes, it's a very easy swap that should only take a beginner a day to do.
Old Feb 11, 2004 | 08:40 PM
Robs97Z28's Avatar
I have the same trouble with My 97 z. I have been trying to chase this down for over a year now. I has been a major pain in the a$$! I have replaced cap, rotor, wires, plaugs, pcm coolant sensor(which did help), and km for LT4. The miss is still there, but I have arise up high in the band from 4.5k to 5k. still looking!
Old Feb 11, 2004 | 08:43 PM
Robs97Z28's Avatar
Oh yeah, you are right about the rev limiter. It is 5750 on the lt1s, but I have rised mine up to 6250 with HP III.
