high pitched squeal coming from engine LT1 engine. Help
Old May 4, 2010 | 11:29 AM
Matts97camaro's Avatar
All
I have a noise that sounds like a altenator squeal. I have replaced the Alternator, idle tensioner pulley and bearing, power steering pump, belt and it still squeals when you give it gas. At idle it makes no noise.
If I take off the serpentine belt and there is no noise at all when I rev it up.
I am stumped on this. Any ideas.
Old May 4, 2010 | 11:58 AM
bw_hunter's Avatar
Only thing left is the AC compressor...
Also, what belt did you use? I've had squeal with new belts until I fit a Goodyear Gatorback....much better than others in that regard.
Old May 4, 2010 | 01:11 PM
My bad, I also replaced the ac acompressor with a 1LE AC delete pulley.
I thinking I might have to replace the tensioner for the idle pulley. That is all that is left.
Old May 4, 2010 | 02:12 PM
Guest47904's Avatar
Guest
Usually belt noise is from a belt that is not tight enough.
Old May 8, 2010 | 10:40 AM
Thanks all
I replaced the tensioner itself and that fixed the problem.
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Jrlt1
Jan 3, 2015 07:38 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
