hi-miler hose install help...
i bought a hi-miler hose kit from summit about two years ago, and im just getting around to installing it. the problem im having is that i dont have an instruction kit. i have researched on their website to id hoses and i could probably match them up, but i would appreciate an instruction sheet or something.
it appears that i may have to hack into some hoses that lead to the heater core, as to separate them from aluminum lines. is that whats called for?
thanks
jb
thanks
jb
Re: hi-miler hose install help...
I used that kit a couple years ago, and I agree that it was confusing. I don't remember how everything went together, but I just matched the hose diameters as best I could and then tried to make everything fit. The hose lengths and shapes were definitely not 'stock', but they worked out eventually. I also needed to pick up some extra hose to complete the set in a few places.
As for the aluminum sections, I just cut off the crimp fittings and replaced them with hose clamps. Be sure to use all the fittings in the appropriate places and directions, though.
Good luck.
Good luck.
SMO Q
Feb 11, 2015 07:13 AM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
