hey I have a simple quick question about the LT1
Old Mar 6, 2007 | 07:24 AM
SinisterSix's Avatar
QUESTION. . .
If you remove the radiator hoes or have a hole in them will the engine start and stay running?
I know eventually it will run hot but will it at least start? The reason I asked is I hade a hose burst and the car will start up but when I give it gas or let it sit for more them 10 seconds it shuts off. .
Old Mar 6, 2007 | 07:56 AM
carguy2112's Avatar
Yes, it will run fine until it overheats. You have another problem in there somewhere.
Old Mar 6, 2007 | 08:01 AM
i'm thinking maybe opti
Old Mar 6, 2007 | 08:03 AM
2000GTP's Avatar
If your opti took a bath in coolant, that could easily be your problem.
Old Mar 6, 2007 | 08:18 AM
do you opti make any noise if its bad??
Old Mar 6, 2007 | 08:21 AM
more like a coolant shower
Old Mar 6, 2007 | 08:28 AM
respectirocz's Avatar
but... that ls1 car doesnt have an opti
i'm confused
Old Mar 6, 2007 | 08:40 AM
hosspwr94's Avatar
visit his page...
thats a 97 with a front end conversion so its still an LT1 car!
I'd say replace the opti! if it overheated that bad you may have also blown a head gasket. check your oil dipstick for any muck, then do a compression test and see if it has good compression that will help eliminate a bad head gasket as well.
i'm confused
Old Mar 6, 2007 | 08:44 AM
i wonder where i can take it to get a compression test in my area
Old Mar 6, 2007 | 08:48 AM
bingo's Avatar
Autozone should have one that it rents out. It would be one of their loan-a-tools.
Old Mar 6, 2007 | 08:50 AM
hosspwr94's Avatar
Yep that would be your best bet.
Its a very simple procedure to do yourself. If you can change the plugs then you can do a compression test. Good luck
Old Mar 6, 2007 | 08:52 AM
lol changing the spark plug on a LT1 is like changing a tire on a 2story dump truck by hand!!! thats not easy at all!! lol
Old Mar 6, 2007 | 09:16 AM
hosspwr94's Avatar
true! if you have any headers installed then it should be easier than if you still have stock exhaust manifolds!
Old Mar 6, 2007 | 09:30 AM
i'm stock
Old Mar 6, 2007 | 09:43 AM
hosspwr94's Avatar
ouch That sucks! me too for now but i'm in the market for hookers! Longtube headers! not the ones you find down main street
i'm stock
