Hey 383 peps gimme some luv
Old Aug 6, 2003 | 11:25 PM
S.J.S.'s Avatar
K guys, looks like I'm gonna go with a 383 on my rebuilt motor for my 97Z. I want a street car, not to ronchy but getting about 375 horses. A local shop here said he'll do it and do the clearance just the short block for 2500 to 3K. Then I know I will need a cam but will I need heads? Rockers? What about the small stuff. Gimme some clues all.
Thanks.....S.J.S.
97z A4 (SPUN BEARING), K&N Cold Air, Flowmaster Cat-Back, March pulleys, MAF, Airfooil, TB bypass, Eibach Pro Kit, and Big as hell 315's on back
Old Aug 6, 2003 | 11:30 PM
Cmr0z28's Avatar
um...400fwhp with 383 cubic inches can easily be achieved with long tubes, a cold air intake and an LT4 hot cam kit
Old Aug 6, 2003 | 11:32 PM
EviLZ28's Avatar
You wont need heads but I would definately do some porting on them. It will help alot! Maybe even a set of roller tip 1.6 rockers depending on cam you are selecting. Better think about a TB and some bigger injectors, plus the computer being reprogrammed. I just Built a 383 with LT4 heads ported and polished. I am running 36 lbs injectors with custom programming.
Old Aug 7, 2003 | 12:39 AM
S.J.S.'s Avatar
Thanks guys...EVILZ you da man. Always leavin god reply's and you got a 383 yeeeha. I'll email you.
ANY OTHER SUGGESTIONS WOULD BE HELLA GOOD
Old Aug 7, 2003 | 10:58 AM
S.J.S.'s Avatar
ttt
Old Aug 7, 2003 | 12:24 PM
Perry93TransAm's Avatar
Hes kinda pricy , I just built a 383 shortblock with scat cast steel crank, scat H-beam rods, KB pistons and all the machine work for 1700$ out the door. I bought a new cam as well so add 239$ and I'm using my previous heads but I cleaned them up a bit (190cc AFRs). A felpro gasket set from O' Reillys is less than 200 $. If youre doing the Labor yourself its well below 2500$. (computer reprogram was free because PCMforless update.)
Old Aug 7, 2003 | 03:02 PM
S.J.S.'s Avatar
Hey Perry when you say previous heads, do you mean stock heads or aftermarket ones you had already? What about TB, rockers and headers?
Old Aug 7, 2003 | 03:53 PM
I already had the AFR 190cc heads previously on the 350. I ported them a little and then had a different valvejob put on them (30 deg top cut). I already had 1.6 comp steel RR, and a ported 52mm t/b. I am using the headers as well 1 3/4 Hooker LTs with a mufflex y, into a 3 inch flowmaster. I should be able to start the new motor next week, I just have to finish detailing everything and such.
Old Aug 7, 2003 | 04:23 PM
Gripenfelter's Avatar
I have a Scat 9000 crank
Eagle H rods
SRP pistons
Total seal rings
XE 230/236 cam
comp R-lifters
fastchip tuning
ported stock heads.
On a car with a 3200 high stall I made 375rwhp. With a T56 you can expect to make 400rwhp.
Old Aug 7, 2003 | 05:46 PM
S.J.S.'s Avatar
where do you guys buy your parts from?????
Old Aug 8, 2003 | 08:20 AM
I bought the crank, rods, and bearings from Northern auto parts. I bought the pistons from Summit, and the heads from North Dallas Exports (www.strokermotor.com)
Old Aug 8, 2003 | 09:34 AM
I got all my parts from www.nu-tekmotorsports.com
Email Nick there and tell him Gripenfelter sent you when you're ready to buy. He's very helpful and will walk you through it.
cristian1311
Apr 22, 2015 10:20 PM
cheapchevy
Apr 8, 2015 08:48 PM
nballisru
Dec 14, 2014 05:01 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
