Hesitation still there!!(Part 2)
Old Aug 23, 2003 | 07:49 PM
SpeC's Avatar
Hey awhile ago i posted about my car hesitating when i stepped on it. Well every1 said to change my fuel filter and I did but it still hesitates!
when in OD i step on it, the car hesitates (kinda stumbles), and then kicks in the power, which seems less than usual. Like i said before i just got a tune up 2 years ago, serviced the transmission a month ago, and just changed the fuel filter.
It seems like something is holding back my car, i have to put my foot in it more and it feels like when you take your intake elbow slightly off. (I mean it feels like there is an air delivery prob). But i checked everything and its all good. K&N Filter was just reoiled a month ago, the vortech intake elbow is secure and has its sensor put in right. I dont know what it could be? faulty MAF? I dunno what to do!
-SpeC
Oh yeah no engine lights come on and no idling probs either.
Old Aug 23, 2003 | 08:26 PM
95BlackTA's Avatar
I have the same problem as you, but when I was trying to fix it, My damn pushrod came off a lifter inside the frikkin motor. SO its broke down as of now.
I changed my fuel filter too, no fix. Get your fuel pressure tested(either get a gauge or take it to a shop, they wont charge you much). If you are low on fuel pressure than its most likely your fuel pump. ALso I hear some things that cause stumbling are bad injector(s)(Which I think is my problem)....bad coil, or plugs/wires.
Some ppl will elaborate on what i said im sure. But I say next step, get fuel pressure tested to rule out fuel pump.
Old Aug 23, 2003 | 08:59 PM
Myxtreme1's Avatar
Had the same prob with no codes. Changed the opti and runs like a champ!!
Old May 28, 2004 | 09:41 PM
meangrn94ta's Avatar
i have the same prob but only at wide open throttle and it studders really bad. i replaced the opti with a good working one no change, replaced the MSD coil with a good working one no change, checked timeing chaing lined up at TDC. i disconnected knock senor ran that crap reconnected ran better but same prob. oh sorry this is after a cam swap and 1.6 rocker and springs and long tubes with true duals on a 94 TA. if u guys have any suggestions pease let me know post back or email me.
mike
Old May 28, 2004 | 09:43 PM
feul pressure is good too between 40-45
Old May 28, 2004 | 10:14 PM
Tim240z's Avatar
Since you mentioned using a K&N, have you cleaned your MAF?
Also check plugs, wires, coil etc...the usual suspects...
Old May 28, 2004 | 11:58 PM
camaro325's Avatar
meangreenta, it sounds like your tps may have a wear spot you should scan your car and see if you get a code for the tps
Old May 29, 2004 | 04:12 PM
AxeGrinder30thZ's Avatar
Check your throttle cable. If it's streched any, it will cause some hesitation.
Old May 29, 2004 | 04:43 PM
KeVMaN's Avatar
Anyone know if a poly trans mount would cause false knock? I have this hesitation problem, and I know the mount makes my car shake like hell...
Old May 29, 2004 | 09:34 PM
What kinda mount do you use? My ES poly mount shakes on hard braking only, and very little shaking at that.
novaiiman
May 15, 2016 11:36 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
