Here, TPIS LT1 Ported Heads Flow numbers
While searching invoices, I found flow numbers for TPIS LT1 ported heads Stage I. Here are the flow numbers Stock Vs Ported from superflow 400 flow sheet from TPIS:
The Heads have 2.00/1.56 valves. Flow sheet is dated March, 2001.
Stock:
.100 58/47
.200 115/93
.300 177/126
.400 214/150
.500 214/159
.600 214/165
Ported
.100 64/52
.200 135/105
.300 193/142
.400 232/165
.500 251/177
.600 251/188
What do guys think of this port job for $1250+core.
Stock:
.100 58/47
.200 115/93
.300 177/126
.400 214/150
.500 214/159
.600 214/165
Ported
.100 64/52
.200 135/105
.300 193/142
.400 232/165
.500 251/177
.600 251/188
Re: Here, TPIS LT1 Ported Heads Flow numbers
Lloyds heads are flowing more than those and cost less. I think his stage one has simular flow numbers and you also get a cam with them.
In my dealings with tpis I have found that they had good product but where almost always over priced.
Their current flow numbers are probably higher. Three years of porting heads on a bench should lead to higher numbers.
just my .02
Kory
just my .02
Kory
yeah, they are always high. and I had a buddy that bought an eng. from them and it didnt last out of the breakin period, he's in court w/them still trying to get his money back. they totally suck as a company. IMHO
chris
chris
i had a buddy with a 408 stroker LS1. Apparently with the ls1's it's critical to clean out all the coolant in the steam ports and all the other little ports in the heads and block before reassembly or else the blocks/heads can crack. Well, he had the stroker built by tpis, and after a few hundred miles his block split, and he go coolant in the oil and the motor seized. Eventually, they built him another engine but they certainly did a good job of trying to blame him and blame everyone else first.
just thought i would let you guys know
trav
trav
True, LE heads are higher flowing.
What you have there, as you mentioned, are 'Stage I' heads. While there's no standard as far as what the flow #'s of Stage I, II, and III should be, Stage I is not going to be the most you can get out of a set of heads - as far as flow numbers, that is.
Remember though, these flow #'s are great for advertising, but the proof is in the time slip and/or dyno improvement if that's what you go by. I could have astoundingly high flowing #'s compared to you, but get dusted on the strip because they actually suck at making power.
Try to find actual results from these guys by those who've used them.
Said results are availble for the 2 biggies on this board - Lloyd and Phil. Can't go wrong either way with them IMO.
oldschool
Feb 9, 2016 09:21 PM
Wilson
Jul 21, 2002 05:08 PM
