Helping or hurting air flow.
Old Jun 20, 2003 | 11:38 PM
Z-RATED94's Avatar
When I first bought my Z there wasn't alot of aftermarket parts for it. One of the first things I changed was the plastic piece that runs from the stock air box to the maf. I think the new one was called a slicktube. That and a K&N airfilter. Last summer I added a scoop (dryer vent) to the splash panel and ran some 4 inch hot water venting from the scoop to the opening of the air box. This is a totally sealed system. It does add 2 more 90 degree bends tho and the venting has ridges. Do you think this is helping or should I get a regular CAI.
Old Jun 21, 2003 | 12:47 AM
9TransAM4's Avatar
prettymuch anything will be better than the stock air box, i say you will be fine, but i would go for the cai, if u have a couple bucks around. i bought my LPE Cai for $159. i love it, and i know it is done right. hell, you could probably pick up a nice used one for 60 dollars or so. you wont regret it.
my .02
Nick
Old Jun 22, 2003 | 01:53 AM
fbird95's Avatar
Like 9TransAM4 said most things are better than stock, there will always be that argument on where to get the coldest air from, and how much of it may be heat soaked. I just have my airbox cut wide open. The only true test would to do a before and after on a dyno. I wouldnt worry about it unless your seriously gonna race the car, i'm sure your set up beats the stock. the only thing i see as posing a minor problem is that the dyer tubing can heat up and soak the air inside with heat.
Old Jun 22, 2003 | 02:26 AM
1994CamaroZ28's Avatar
heres a pic of what i did on my car,
http://hav0k.hypermart.net/under.jpg
Old Jun 22, 2003 | 07:59 AM
CANTONRACER's Avatar
I would have made it bigger.
Old Jun 22, 2003 | 07:02 PM
fbird95's Avatar
1994CamaroZ28 did you have any problems with dirt getting up the metal inlet and inside the underside of the bumper?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Fatdog2
Feb 13, 2015 08:19 PM
95chwagon
Jan 13, 2015 09:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
