Helpful hints on thermostats plz
Old Sep 22, 2003 | 01:17 AM
NewbieWar's Avatar
in the morning im gonna change mine... just wanted to know any hints u guys might have before i start...
Old Sep 22, 2003 | 01:21 AM
Spinner's Avatar
One of the easiest installs to do. Make sure your motor is warm-cool (doh.) Take the radiator cap off to vent pressure, you can put it back on after pressure is vented (wait 3 secs). Just be prepared for a bit of coolant to spill out. Take old thermo out. Put new one in. Simple. All you have to remove is the intake elbow.
Old Sep 22, 2003 | 01:26 AM
Zack's Avatar
i read in another post that you bought one. did you get the right one? A standard Small block chevy one wont work
Old Sep 22, 2003 | 01:34 AM
GrayPurpleTA's Avatar
Make sure you cover the opti. Never wanna have anything spill on that.
Old Sep 22, 2003 | 01:37 AM
Fastbird93's Avatar
If you want to do it without making a mess, drain some fluid out of the radiator, say like 1-2 qts of fluid should be fine. That way, you get the top level down, draining the upper coolant line so that there's nothing to spill on the opti when you remove the thermostat neck.
Old Sep 22, 2003 | 07:36 AM
Themostat change
Old Sep 22, 2003 | 07:49 AM
Derrick Redd's Avatar
Follow Shoebox's link. Make sure you bleed the system after completion.
grgguy
17
Feb 23, 2015 07:57 PM
phoenix95
Jan 8, 2015 02:44 PM
mattszm6
Dec 14, 2014 07:09 AM
NewsBot
Dec 3, 2014 12:30 PM
