Help! what oil pump drive gear to use
Old Jul 1, 2007 | 09:11 AM
red 95 z28 lt1's Avatar
since my engine has been built i was using the stock oil pump drive gear, ive had the cam for 3 years now its a le2, it sheered 4 teeth on the dyno(lucky the tuner caught it in time) but it looks like its been wearing for a long time, is there supposed to be up and down play with the gear/shaft assembly? ive got aprox 10000 miles on this engine too, i also have a melling high volume oil pump,
which gear should i be using, i just hope the cam is ok.
Old Jul 1, 2007 | 10:44 AM
Projectz28's Avatar
Moderator
That all depends on what gear is on the cam. Whats gear is on the cam? do a search for oil pump drive gears and you will find tons of info out there on what gear to use.
Old Jul 1, 2007 | 11:47 AM
You may just have to plan on changing it every so often. HV pumps put more strain on the gear. You might consider a lighter oil to relieve some of the stress.
Old Jul 1, 2007 | 11:58 AM
yea i have to dig out my cam card,
what if i were to use a bronze gear, will that in time eat up the cam gear?
Old Jul 1, 2007 | 02:45 PM
Projectz28's Avatar
Moderator
Bronze gears are soft and they will eat up themselves before the cam gear. But with the wrong combo you will go thru a bronze gear in 100 miles... find out what gear is on the cam then you can make a choice as to what gear to use on the drive. As shoebox said HV pumps add some stress and are harder on them.
Old Jul 2, 2007 | 06:11 AM
im still looking for my cam card i dont know if its a billet cam or not, what drive gears are available for the lt1 engine and what material are they made of?
Old Jul 2, 2007 | 12:16 PM
1redTA's Avatar
re
use the polymer gear from Comp we used it when my friend got a billet cam and it would eat the gears, iron or brass, especially the brass had it on the street for 3 years now no problems. Measure the diameter so you get the right one we had to machine a bushing for ours Art
Old Jul 2, 2007 | 07:16 PM
wait i dont understand, ur not making sense, first u say that it would eat iron or brass, then u say that u had brass and it lasted 3 years on the street no problem,
on another note, i found my cam card, what do i have to look at to find out if its a billet cam?
Old Jul 6, 2007 | 01:40 PM
what is the size of the gear i need a bronze one i have a billet cam
Old Jul 6, 2007 | 02:27 PM
It's hard to follow, but I believe he is saying the polymer lasted 3 years...
Old Jul 6, 2007 | 04:12 PM
1redTA's Avatar
re
my bad, the polymer has lasted around 3 years and no problems as of yet
Old Jul 17, 2007 | 11:18 PM
i put the bronze gear in, according to lloyd, thats what i need, i also called comp cams and they said i need the bronze gear as well. all is good so far but im still gonna be a little nervous for a while, lets see what happens
Old Jul 18, 2007 | 03:01 PM
tireburnin's Avatar
It will eat the bronze gear too.
Only a matter of time. Just keep it in the back of your mind that you need to watch your oil and check the gear every so often.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Elcojoe
Nov 17, 2014 10:27 PM
