Help w/ engine swap.....
Old Dec 16, 2006 | 05:34 PM
2fbodies2NV's Avatar
Question Help w/ engine swap.....
Maybe someone can tell me where I screwed up. I just finished putting the new motor in my 94 TA. I got no spark. Everything I can see is plugged in. Everything else worked when I pulled the motor. Is it possible to install the opti or the drive wrong??? Been here since lunchtime finishing up to get here.
Old Dec 16, 2006 | 09:37 PM
Dave89IROC's Avatar
how did you pull the motor?
and go here http://shbox.com/1/4th_gen_tech1.html , there is a walk through to check for opti signals IIRC
Old Dec 16, 2006 | 09:39 PM
Dave89IROC's Avatar
yeah, here it is http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Dec 17, 2006 | 09:00 AM
I dropped the motor and trans out the bottom.
Old Dec 17, 2006 | 10:17 AM
Dave89IROC's Avatar
are the plugs under the pass kick panel all pluged back in?
Old Dec 18, 2006 | 12:17 AM
I unplugged everything from the components and left the harness in the car. If I didn't line up the opti right, like if I accidently got it on 6 instead, would I have the same problem? My brother and I both looked over the whole car and couldn't find anything that was unplugged.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
