Help With Valve Covers
Old Mar 2, 2006 | 10:39 PM
sick-1's Avatar
Ok here is the deal, i took Lloyds advice and got the comp pro magnum rocker arms, well problem is that they are not a narrow body rocker arm and now the valve covers wont go back on. what to do, new vavle covers or new rocker arms????
Old Mar 2, 2006 | 11:04 PM
Re: Help With Valve Covers
If you do a search, you will find many threads with the same question and how you need to make some slight changes to the interior webbing of the stock valve cover.
Old Mar 2, 2006 | 11:12 PM
sick-1's Avatar
ok thanks shoebox i actually figured that out just before you posted, should have thought about it a little harder first huh haha. for any body else just bend the very ends of the webing flat to clear the rocker arms.
Old Mar 3, 2006 | 02:50 AM
SS RRR's Avatar
Yep... Just make sure the braces aren't touching the the rockers after you get done bending. They tend to distort a bit after being bent.
I always prefer this method over just cutting them. I've cut the braces out on two sets of covers before and had nothing but leakage problems.
Old Mar 3, 2006 | 03:40 AM
Silvershark's Avatar
Check this link.
http://web.camaross.com/forums/showt...29#post3593029
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
