help! tranny might be going!
on my way to school today , everytime i was at a stop and pressed the gas down halfway , my car would make a bump bump bump noise and the gear selector and the whole console would shake vigorously. but it only happens when i hit the gas from a dead stop or if im rolling slightly . has this happened to anyone? will i need a new tranny or can it be fixed?? please help asap!thanks
the car has 52k miles on it , im not sure if the tranny fluid has been changed or not , would doing that help at all?
Sounds to me like your trans mount is broke,thump,,thump.:mad:
yeah thats what i was thinking and it does sound more like thump thump thump. how much do u think it will cost?
If you do it yourself ,around $20.00 and half an hours time.Remove two boltts,jack up the tranny and replace.
About $45 at a shop
Trans Mount, no one has broken one in a while
a buddy of mine that does trannies said it could be either a 1 piece mount or the 2 piece mount that mounts around and the tranny and to the diff. , im just going to do both of the mounts so i dont have to be worried in the future , also im going to change fluid out. any recconmendations on what brand i should go with?
thanks |
turned out to be the engine mount! got it fixed and used redline tranny fluid! thanks for the help guys
