HELP!! (TPS-Car not shifting)
Old Feb 22, 2003 | 10:17 PM
n64man's Avatar
Angry HELP!! (TPS-Car not shifting)
I unplugged my TPS sensor while the engine was running and of course a SES light came on. Now I can't get rid of it, and the car won't shift out of third gear. I've even replaced the TPS and can't get the SES light to go off. And yes I've reset the computer..
I don't have any way to check codes, since I don't have a scanner..
any suggestions?? Please HELP!!!
I have a 95 Z28..
Thanks!
Old Feb 22, 2003 | 10:25 PM
Start by checking all your fuses. The pcm is trying to tell you what is wrong, but without a scanner you can't hear it. Bottom line is to get a scanner or get it scanned to see what is wrong. By the time you guess and waste money on stuff that is not the problem, you could have bought a scanner.
Old Feb 22, 2003 | 10:29 PM
n64man's Avatar
would the TPS cause the cat not to shift correctly??
Old Feb 22, 2003 | 10:36 PM
The pcm uses throttle % and speed to determine shift timing, so the TPS signal is vital.
Old Feb 22, 2003 | 10:40 PM
n64man's Avatar
oh yeah, and I checked for 5v at the TPS and it's there...it also changes as the throttle moves...
of course the code could be something entriely different, so who knows :-)
kinda shotting in the dark!
I was gonna have Autozone scan my car for the code, but they "didn't have time" so I'll try later I suppose...
and thanks for the replies shoebox!
Old Feb 23, 2003 | 01:31 PM
n64man's Avatar
ok, got the car to shift properly....so that is no longer a problem. I also had the car scanned...I'm getting a code 48 (MAF)
Is there anyway to check the MAF?
Could the MAF be causing the surging/stumbling problem I'm having at accelration (even before the SES light was on)
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
