help it stopped running
ive got 93 z28 and yesterday . car started missing then it was shaking lil ,car stopped running ,and it want crank up again , ive put new plugs and wires on it changed oil , fixed mount on transmission ,even had put new frontend under it , ive put like 2300 dollars in it in 3 weeks .. yesterdasy it started missing and stop running ,whats wrong with it ,i need help
Re: help it stopped running
You aren’t going to get a lot of tech help in “Site Help and Suggestions”. It’s for issues with the way the site software performs. I'll move this to “LT1 Based Engine Tech” for you. Have you scanned it for codes (very easy to do on a 93, no scanner required)? Have you checked the fuel pressure? Have you checked for spark at the plugs and at the coil wire? Did you replace the plugs and wires BEFORE or AFTER it stopped running? |
| All times are GMT -5. The time now is 02:48 AM. |
