HELP SHOEBOX! Broke A.I.R. Diverter Valve
Old Jun 23, 2003 | 09:05 PM
AENIMA95z28's Avatar
Ok when i stated i broke my EGR earlier i was on crack (j/k) i meant my A.I.R. Diverter Valve on the passenger side. The part that broke was the metal tubing that runs into the exaust manifold. I need to order the new one ASAP, do you or anyone else know the part number. Also, is there any kind of Temp fix for this till the part comes in ?
Old Jun 23, 2003 | 09:12 PM
Anyone ?
Old Jun 23, 2003 | 09:18 PM
If it is the first design one like in the bottom of this pic, it is GM PART # 10244578 .
Old Jun 23, 2003 | 09:20 PM
mines a 95 z28 , im not sure what version it is, how might i tell. also, when i order the part, does it come complete with the entire diverter valve (part that screws into manifold all the way to the rubber hose)?
Old Jun 23, 2003 | 09:24 PM
It looks just like the one in the picture but im not exactly sure the differences between the first design and any other designs
Old Jun 23, 2003 | 09:37 PM
Anyone know who can over night parts or do second day. Gmpartsdirect.com only does ground
Old Jun 23, 2003 | 09:46 PM
The first design is like the pic with the loop that comes back on itself. It doesn't come with the check (diverter) valve.
The second design looks more like the driver's side.
Old Jun 23, 2003 | 09:50 PM
Ok great, mine has that loop. I ordered the piping with the part number you supplied me with. Do you recomend i buy a new diverter valve too? I really appreciate all your help, this isnt the first jam youve helped me out of.
Old Jun 23, 2003 | 09:52 PM
No need for a new valve if the one you have is working.
Old Jun 23, 2003 | 10:37 PM
if you dont mind explaining what is the purpose and function of that thing.
Old Jun 23, 2003 | 10:42 PM
It is a check valve that allows air to go in the direction of the manifold, but keeps the exhaust from going in the direction of the AIR pump. When the valve fails you will know, because the rubber elbow hose will melt from the hot exhaust gases.
Old Jun 23, 2003 | 11:36 PM
1982z28with18s's Avatar
Yep, the hose will melt, and also the diverter valve might change color, almost to purple. Mine just did this last week.
Old Jun 23, 2003 | 11:37 PM
revtime's Avatar
Wow, sounds complicated, I am glad I threw mine in the trash.
Old Jun 23, 2003 | 11:53 PM
matt diamond's Avatar
me too
Old Jun 24, 2003 | 07:54 AM
Darn. You could have sold parts to AENIMA95z28.
