Help!! SES and Running HOT!
Old Jul 30, 2004 | 11:25 PM
Kataklysm's Avatar
Well last night the SES light came on so I figure no big deal I"ll just shut it off for a minute then restart and it will probly go away. I do this with no avail. So I figure maybe tomorrow morning (today) it will be out, still on. So tonight I was driving for about 30 min (85 degrees outside) and the SES light is on the whole time then I come to a stop and realize the temp is up to about 250! I'm guessing the SES light is telling me something about the cooling system since I have a 160 thermostat and it has NEVER gone above 190 with this thermostat. Opionions would be greatly appriciated, the car will be getting scanned or at least getting a code pulled to figure something out. Thanks.
Old Jul 31, 2004 | 12:21 AM
Re: Help!! SES and Running HOT!
Could be that the fans are not working. Check the fuses. The scan should help.
Old Jul 31, 2004 | 04:55 PM
Kataklysm's Avatar
Shoebox It was the fan actuator fuse. I'm really surpised the SES light came on due to a fuse though, never knew that. Thanks for the help I never would have checked fuses for this.
Old Jul 31, 2004 | 10:39 PM
Kataklysm's Avatar
Well, I thought it was fixed...now it just blows fuses every 5 minutes. Its the 10 amp fan/actuator fuse that keeps blowing out. I replace the fuse and the SES goes off and the temp stays perfect...all the sudden the light comes on and the temp steadily climbs. Now what?
Old Aug 1, 2004 | 12:04 AM
Bow94z's Avatar
yea i was gonna say the same thing. dont the fans turn on high speed when SES light is active. usually my car wont go past 170-180 wih fans on high speed.
Old Aug 1, 2004 | 09:01 AM
That fuse powers numerous things:
oxygen sensors
fan relays
reverse lockout and skip shift solenoids (if manual trans)
EVAP solenoid
EGR solenoid
The most common thing is a burned and grounding out O2 wire, if you have headers.
Old Aug 1, 2004 | 10:46 AM
Kataklysm's Avatar
Well I checked the O2 wiring and it looks fine, nothing melted and the plastic around the wires isn't even punctured. I put a 15 amp fuse in instead of the 10 amp just to see what happened...at idle the fans came on about 6 times without blowing the fuse so I decided to take it for a drive. After 5 min of driving the fuse blew out again....so this means my fans are drawing to much current correct?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
calaban
May 18, 2020 06:43 PM
Collector Car
Dec 17, 2014 01:12 PM
CLEAR
Aug 30, 2002 07:49 PM
