help selecting cam for ported stock heads
Old Aug 5, 2007 | 04:29 PM
11secgen's Avatar
i need help selecting a cam that works well with ported stock heads.il be useing the stock computer,so ill want it to peak out at about 6800.my engine specs are as follows:
billit splayed caps
eagle h beams 6.0
mahle power pack
scat 4340 3.48 crank
comp cams shaft rockers(overkill i know, but there so damn cool looking!)
fully ported lt1 intake
ported 342casting heads, flow @ .600 is 283 and 191
so what cam would work well peaking around 6500-6800?
Old Aug 5, 2007 | 04:31 PM
mdacton's Avatar
847 will probly work fine....
what are your other goals? street car, drag car?
Old Aug 5, 2007 | 04:51 PM
96capricemgr's Avatar
Important question would be are you going to put this through Chicago emmissions inspection?
Old Aug 5, 2007 | 05:08 PM
'94 Bad A Z28's Avatar
You want it to peak at 6800 or you want to shift by 6800?
Old Aug 5, 2007 | 08:43 PM
RRR's Avatar
RRR
billit splayed caps
eagle h beams 6.0
mahle power pack
curious who ported these?
Old Aug 5, 2007 | 11:29 PM
11secgen's Avatar
its a 95, so no emmisions,no cat and i got the block off kit for the egr and air.
i ported these! with a little help from a buddy.i spent 3 hours on each intake and 2 hours on each exaust.the exaust is ported out all ther way, where the intake is ported less.i did this because the intake flows so well.the valve pocket is seriouly ported out on both.these will prob crack, but then ill have an excuse to get some cnc lt4 or ported afr's.my neighbor works at mpg,they build nothing but crazy 2000+ hp drag engines for top teams in the midwest and all over,plus they can port.im going to drive the car on the street,but i dont want to leave anything on the table.only drivin to the track and maby to work once a week.id like to make peak power loe enough to shift below the 7000- 7200 rpm max for the stock computer, so i guess it should realy peak at about 6500.
thanks so much for all of your help.
dan
Old Aug 5, 2007 | 11:39 PM
11secgen's Avatar
i forgot to add that the rockers are 1.6.
Old Aug 6, 2007 | 07:15 AM
FASTFATBOY's Avatar
Alot of people have had good results with "off the shelf" cams such as:
Comp XE 230/236
GM 847
GTP 5 and 6
COmp 306
Also call Crower they ground me a custom cam at one time in a 355, it was small but ran 90 MPH in the 1/8 mile with a weight of 3700 lbs. They put that cam into their "lineup"
David
Old Aug 6, 2007 | 09:33 AM
maybe2fast's Avatar
503 is a good street cam
Old Aug 6, 2007 | 10:32 AM
urbaNHunter44's Avatar
take a look at comp's XFI grinds, I love the XFI grinds, they've got plenty of lift to take advantage of the heads.
Old Aug 6, 2007 | 12:05 PM
Z-RATED94's Avatar
Many good suggestions here. But, the best way to find the right cam is to try out different ones and see what the motor likes. Your not against swapping out cams at least half a dozen times, are you?
Old Aug 6, 2007 | 05:17 PM
11secgen's Avatar
haha, if i have to.this started out as a blown head gasket so im not afraid to tear it apart a couple of times.i thought i would buy a extra block to slap some new bearings and rings in so i could just swap motors one weekend.next thing you know im buying shaft mounted rocker arms and splayed caps.you know how it goes.i think ill try out the 847 first though.it looks good w/ the extra exaust duration and lift,to get that nitrous out.
Old Aug 6, 2007 | 05:19 PM
Z-RATED94's Avatar
On a 175 shot, right?
Old Aug 6, 2007 | 08:34 PM
11secgen's Avatar
maybe even 200 shot with the mahles in there.its a dry shot.
Old Aug 6, 2007 | 09:22 PM
Z-RATED94's Avatar
Yeah baby!!! Throw an extra pair of shorts in the glove box, just in case.
