Help sealing primary #1 slip-fit
Old Mar 3, 2004 | 06:40 PM
PatriotTA's Avatar
I have done a search and didn't turn up anything good. The slip-fit on the Hooker #1 primary is loose. I saw that Permatex has a high-temp metal repair that says on the package "good up to 2000 deg F, for exhaust manifolds/headers." I'm planning on using that and having the primary expanded. Has anyone had any problems taking the primary to an exhaust shop to have it expanded (ceramic cracking or anything) and how much does it usually run to have that done? Thanks.
Old Mar 3, 2004 | 08:44 PM
PatriotTA's Avatar
anyone?
Old Mar 3, 2004 | 09:08 PM
leadfoot94's Avatar
I ended up just using a manual style pipe expander. You know the ones that look like they are made of orange slices with the nut you tighten on one end. I expanded it slightly and it sealed right up after that. Or I have heard of people actually having to weld it together.
Old Mar 4, 2004 | 08:27 PM
Dragon Racing's Avatar
I ordered a t-clamp from Summit and it got rid of my header leak.
93 RedBird
Nov 15, 2015 08:24 AM
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
