Help! Rough Idle in Open loop
Old Aug 24, 2004 | 06:25 PM
ScrmngChckn95's Avatar
My car has been idling pretty rough since I got it, but especially now that I've changed the O2s when I did the header install. It only happens in open loop, and strangely the idle gets worse the longer I let it idle there. I KNOW the wires are good since I just did them about 2 weeks ago. Also I've changed the plugs maybe 5k miles ago too.
The car feels strong through all the rpm band, no hesitation or stumble, just has a really shakey idle. The rpms don't really seem to bounce around at all at idle either, maybe about 20rpm, buts its hard to tell its moving so little. Also I have 2 small rips at the base of my intake elbow, I'm going to replace it soon, but I don't think they're bid enough to hardly let any air in. Any ideas?
BTW, the opti was changed 15k ago, and the fuel filter about 5k ago.
Edit: I had a local meineke weld my y-pipe to the cat, and they had to remove the y to do the weld. I noticed that they rerouted the wires for the drivers side O2s when they reinstalled it.
Old Aug 24, 2004 | 07:34 PM
Re: Help! Rough Idle in Open loop
could it be my EGR valve? I have been getting an code 32(egr fault code) but only on the highway in sixth in cruise.
DirtyDaveW
Dec 1, 2016 05:37 PM
markzzzz
May 8, 2015 09:21 AM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Fred94LT1
Aug 24, 2002 08:07 AM
