Help please - Lights on dash,radiator, ABS, Security
Old Sep 4, 2006 | 01:02 PM
herz28camaro's Avatar
Exclamation Help please - Lights on dash,radiator, ABS, Security
Hello all,
I would appreicate any and all assistance. My dash is lighting up like a Christmas tree.
the following light are on:
Radiator - full of coolant and the reservoir is fine.
ABS - Changed the breaks still light is on
Security - alarm works fine, car starts fine
No problem with the car expect these lights..
Old Sep 4, 2006 | 01:08 PM
OBE1 95Z28's Avatar
Re: Help please - Lights on dash,radiator, ABS, Security
Try cleaning the ground post located on your passenger side inner fender, next to the red positive post. Disconnect the battery, remove the grounds from the stud, remove the stud and sand off the paint under the stud. Clean all the connections and reassemble.
Old Sep 4, 2006 | 01:21 PM
Thank you I'll try that.
Old Sep 6, 2006 | 09:38 PM
didn't work still have the problem...help...
Old Sep 6, 2006 | 09:56 PM
Andrew R's Avatar
Unplug the sensor below the radiator cap, that will take care of the coolant sensor.
On the ABS light, check your third brake light, I know that sounds weird, but if it is burnt out it will cause the ABS light to appear. It happened to me, and stumpped me for months, untill I asked about it on here.
As for the security light, thats beyond me.
Magenta_Hearts
Mar 29, 2017 08:54 PM
jj_burchiel
Mar 21, 2015 12:51 AM
squarehead
Jan 15, 2015 07:02 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
