help please guys
help please guys
I have a 69 camaro with a lt4 in it and seems like it is hitting a rev limiter above 5100 rpm it has a new alternator, new msd coil, newer msd opti, new plugs and wires. here are the specs on the engine
12:1 compression
Eagle h beam Rods
Eagle crank
Srp pistons
Tea stage 3 LT4 heads with port matched LT4 intake
Arp head studs
Arp main studs and rod bolts
comp 987 dual springs
titanium retainers
custom ground cam fro TEA 236/246 610intake
618exhaust 114LSA
30lb injectors
Hardened pushrods
high volume oil pump
MSD opitspark
New GM waterpump
Holley 58MM throttle body
PCM with motor tune in it
total seal rings
4 bolt main
clevite bearings
0 decked
balnced and blue printed
The tuner also said that alternator voltage was reading 14.1 but at the coil it was reading 12.6 then it drops to 11.6 to 11.4 in the upper rpms. He also said that the actual igintion timing that the scan tool is showing does not match the targeted spark in the wideopen spark table.
thanks guys for your help the tuner didnt seem to be much
12:1 compression
Eagle h beam Rods
Eagle crank
Srp pistons
Arp head studs
titanium retainers
618exhaust 114LSA
30lb injectors
Hardened pushrods
MSD opitspark
New GM waterpump
total seal rings
4 bolt main
clevite bearings
0 decked
where is your voltage drop at the coil power feed? if so what about running a heavy wire straight from the battery over to the coil to make sure it has a good feed. What about an ignition box? are you running one? somebody didn't stick a 5k pill in it did they? If you aren't running a box you probably should be.
I honestly don't know about Voltage drop to coil. Do you still have the coil mounted on the front of the head? It should have a body ground strap going to that stud in the head that the coil assembly mounts to as well. Is it just going flat at 5100 or actually studdering like a mis? Are you sure the opti , cap and rotor are good? also check those plugs for the opti for corrosion, both ends( electrical wires not plug wires). Is the car strong to 5100 like it should be?
the coil is mounted to the head. I dont have a ground strap hooked up to that stud its grounded elsewere but i will put a ground to it for *****. It runs pretty damn strong up to 5100 its making 385 to the wheels at around 5000.
carguy0119
Apr 11, 2016 11:11 PM
mspennyhughes
Nov 28, 2014 03:22 PM
