Help please.
Old May 7, 2005 | 09:55 AM
desertfox's Avatar
Help please.
I did search this forum, but I couldn't find anything about how to install back the crank shaft pulley. It was really hard to took off, and I would appreciate some addvise. (Can I heat it up a little to slide easier on the shaft?) Thanks.
Old May 7, 2005 | 10:17 AM
OBE1 95Z28's Avatar
Re: Help please.
I use a threaded rod as a stud and then pull the crank pulley into position with a nut. I also use a bearing between the nut and the pulley to reduce friction. A couple of large washers will also work.
navtool.com
Sep 24, 2015 03:30 PM
navtool.com
Sep 24, 2015 03:26 PM
navtool.com
Middle Atlantic
Sep 24, 2015 03:17 PM
Daluchman1974
Sep 11, 2015 06:12 AM
mlopezart
Sep 8, 2015 12:15 PM
