HELP! no power, won't start!
Ok, I just changed the oil on my car because its been sitting for a couple of month due to my licence being taken away. Anyways I did the change started it up ran it, turned off then checked oil. It need at tiny bit more so i topped it off hopped in turn the ignition and nothing! no radio, no interior lights nothing. Batter has 12v and i checked all the fuses in the engine compartment and interior. Are there more fuses or an inline fuse somewhere I dont know about?? Any input would be great.
Thx, Adam
Thx, Adam
Thx for the suggestions, im going to play around with it when i get home from work tomorrow and I'll try taking off the cables and checking connections. Again thanks for the input
Thx, Adam
Thx, Adam
Arent u not supposed to fill up the oil allll the way????? Doesnt it like over flow into the cylinder heads or something??
Check your battery cables? Maybe one is corroded or loose. My first thought was VATS, but you said you had nothing at all, wierd...
