Help with no crank...
Old Oct 24, 2004 | 06:26 PM
Zrag's Avatar
Got my new eng in and now I've got a starter problem. When I hit the key you hear a loud tapping sound not a click, arm is being thrown out hitting the flywheel but not turning it over. I put in a new starter same thing. Checked wire coming from key ok and main wire from battery ok. When I pull out the new starter and jump it with the jumpers starter works. I turn engine over by hand ok too. Battery has sat for 2mos or so did a two day charge and use a jumper to try a start too... No luck. I'm going to get a new bat but everything worked before rebuild.
help...there little left it could be. Also did turn over at my shop with a large jump box.
thx
Old Oct 25, 2004 | 10:13 AM
Zrag's Avatar
Re: Help with no crank...
ttt...
Old Oct 25, 2004 | 10:48 AM
BlownF1's Avatar
I'm at a loss and just guessing, but have you tried shimming the starter? Is the flexplate the right tooth pattern? <shrug>
DirtyDaveW
Jul 29, 2013 03:56 PM
350350
Feb 5, 2011 08:19 PM
ShownomercyZ28
Jan 1, 2009 05:28 PM
popo8
Sep 20, 2008 03:22 PM
firebirdStud
Apr 22, 2008 08:15 PM
