Help needed ASAP, slave cyl. won't go in
Old May 2, 2004 | 01:01 PM
Camaro37's Avatar
Thumbs down Help needed ASAP, slave cyl. won't go in
Finishing up my clutch install and my slave cylinder won't go back in. I place the end of the pushrod in the clutch fork but then it won't compress enough for me to bolt it up.
When out, the pushrod hangs loosely and can be moved around alot, I cannot seem to push it in any though. Also the clutch pedal is hard as a rock, I could probably push it in but I don't want to break anything.
Ideas?
Old May 2, 2004 | 01:04 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
You did reinstall the aluminum spacer between the bellhousing and slave, correct?
Old May 2, 2004 | 01:25 PM
Camaro37's Avatar
Yes, thats back in where it goes. I think the problem is that the cylinder just isn't compressing, but I don't know why or anything.
Old May 2, 2004 | 05:58 PM
R8E1D's Avatar
did you put in abrand new one and have to fill it with fliud?
Old May 2, 2004 | 06:50 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
you should be able to push it in by hand, but its not exactly easy..
Old May 2, 2004 | 08:38 PM
Camaro37's Avatar
Thanks guys I got it in, I decided to not be a wiener and pushed hard like Jordan said. I didn't try that before cause I was afraid to break something.
Muchas gracias
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
