Help need a piston ring set..
Old Nov 14, 2006 | 11:47 PM
hotrod18_69's Avatar
I have been searching for the best 2 hours and haven't come up with much for a good stock replacement ring set.. I would like Speed Pro Plasma Moly rings. I found a part # E350K but when i bring it up at summit it doesn't say anything about them.. Are these the right ones, if not does anyone have have a part # to them and where i can get them..
Thanks Brad
Old Nov 15, 2006 | 04:22 PM
quickSS's Avatar
OEM LT1 piston ring, Mahle part number 2M4626 (which might look like a Hastings part number because it is). 101.663mm bore, (4.002")
Try that part number at any parts store and ask for Hastings 2M4626.
It should be 2.0mm #1 ring, 1.5mm #2 ring, 4.0mm shallow oil ring groove, light weight.
Karl Ellwein
PS: edit...and that is a plasma Moly ring
Old Nov 20, 2006 | 12:25 PM
quickSS's Avatar
Photo of stock LT1 Mahle rings
LINK to photo of the box of LT1 rings from Mahle
Karl
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
mmf_1013
Sep 12, 2015 08:56 PM
