HELP!! my z28 is screwed up... Suggestions please?
alright anyone out there please help me, i replaced the fuel pump on my 1994 z28 it is still not getting a single drop of fuel to the rail
, i checked the relay and it's fine i need help. please give me ur suggestions,
also dropping the fuel tank wuz a pain in the *** i didnt even get it out all the way, would it be ok to cut a hole through the trunk to get access to the tank? :mad
, i checked the relay and it's fine i need help. please give me ur suggestions,also dropping the fuel tank wuz a pain in the *** i didnt even get it out all the way, would it be ok to cut a hole through the trunk to get access to the tank? :mad
no my pump doen't prime and i can't find the fuel pump fuse so some one please help if u can give me specific intructions to find it, i got a new fuel filter but wuts the use the pump is not even priming up
http://shbox.com/1/fuel_pump_prime.jpg
find this connector right next to the pcm and give it power. it is supposed to bypass the relay and fuse supplying direct power to the pump. also try doing a search. there are so many threads on fuel pumps and wiring problems it will take a day to read them all.
A clogged filter will prevent the fuel from pumping. Can you suck water thrue a clogged straw?
If it's not priming, then you probably have a loose connection where you installed the new pump. I've had non-stop issues with my Walbro and the grounds not wanting to make contact at all times. I'm getting ready to pull it back out and solder everything to ensure contact. It'll take me 5-10 min to have the assembly out, if that helps with your perception of the trap door method. A multimeter can be your best friend with issues like this.
mspennyhughes
Nov 28, 2014 03:22 PM
squarehead
Nov 21, 2014 08:02 PM
F(ast)-body
Feb 26, 2003 09:05 AM
