help with miss 95 Z28
Old Jul 10, 2007 | 08:38 AM
wirewiz39's Avatar
I have a 95 Z28 misses badly under load. I noticed this morning that when the car is cold there is little or no miss. within 5 minutes the miss is back. I am curious....Opti?.....( new wires, plugs, fuel filter, fuel injector flush...any ideas?????????? Car is in the shop today.
Old Jul 10, 2007 | 10:24 AM
EnerjetF67's Avatar
I'd bet you have an ignition wire(s) going bad.
My car acted exactly like this when the wires were going bad...fine cold and as soon as hot there was a hideous miss.
A new set of MSD wires solved the problem....might as well change the plugs and coil while you are at it.
Old Jul 10, 2007 | 08:50 PM
wirewiz39's Avatar
thank you for your reply
I have already done plugs, wires, fuel injector flush, fuel filter.....but you are right when my wires got replaced the problem went away for a while
Old Jul 10, 2007 | 09:34 PM
showstoppers-96-Z/28's Avatar
the stock/oem wires have a habit of burning up and going bad, i've put on 3 sets in just over 1 year! They're in a horrible location, surrounded by hot @$$ exhaust and emissions piping, running right underneath a serpantine belt, theres a toooooon of things that can go wrong with them, id still give them a check at night, see if you spot any fire works.
Old Jul 10, 2007 | 09:57 PM
wirewiz39's Avatar
I put on new AC Delco wires, and now that you mention it this miss is exactly like the one that I had before. So it seems as though I could have gotten a s**tty set of wires right out of the box!
Deadbolt24
Jan 19, 2015 01:29 PM
fpete1992
Dec 11, 2014 03:51 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
