help me squeeze more out of my lt1
Old Oct 17, 2003 | 09:52 PM
CGrant's Avatar
Ok, I dydno'd a 360 with the mods listed below, I feel it is alittle low for my setup, I dyno'd on a dynojet.
stage 2.5 heads w/portmatched intake (outflowed tea's)
comp springs
comp 230/236 @112 lsa
comp 1.6 rr's
compr lifters
comp pushrods
csi water pump
cloyes timing chain conversion
jethot longtubes
offroad y-pipe
capped borla (was told that uncapping wont make much difference)??
2600 stall (swapping to 3000 this winter)
built 4l60e
3:73's
k&n fipk
msd ignition
ngk tr6's
All the free mod's
30lb svo injectors
tuning is "dead-on"
I now have a stock fuel pump that I am swapping out to a 255l,
I ran out of fuel pump at about 6k, I want to take it to 6200rpm
I have heard that a bigger throttle body wont make much difference??
Will underdrive pulleys help much??
What do you guys think?
Old Oct 17, 2003 | 09:58 PM
80TA's Avatar
Yes get pulleys..
Yes opening borla should help also.
And good tuning makes big difference..
Old Oct 18, 2003 | 12:46 AM
Z95m6's Avatar
who did the heads and what did they flow. You are down on power compared to your mods.
Old Oct 18, 2003 | 01:00 AM
stevil's Avatar
Opening up the Borla will help. On a heads and cam car, a bigger throttle body should help some, it wouldn't on a stockish car (maybe that's what they meant).
Old Oct 18, 2003 | 01:09 AM
96LT14u2Nv's Avatar
open the borla (full) and get an ASP underdrive pulley. a bigger TB will help in your application INMO. work on tuning a little more too
Old Oct 19, 2003 | 07:44 PM
CGrant's Avatar
Loyd did the heads and they actually outflowed the tea's, So I dont think that is it, FLP did the tuning and the air/fuel ratio is dead-on, So I dont think thats it.
I would think that I should be more around 400 rwhp for my mods.
I am not sure what to do next?
Noer
Feb 28, 2015 11:29 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Hurin
Dec 13, 2014 07:38 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Makaveli
Jul 24, 2002 11:27 PM
