help me plz!!!!
Old Apr 4, 2004 | 12:45 PM
cridom's Avatar
Angry help me plz!!!!
whenever i start my car in the morning even if it isnt cold outside my car starts as if it where a dragster like cammed or somthing . uit takes a few tryes to start and idle is rought. i can also smeel some gas but i guess is becasue of the times i tryied to start it .could this be the opti or is fuel related?
help plz. thanks
Old Apr 4, 2004 | 12:50 PM
Daryn95Z's Avatar
Mine does the same thing, but in every kind of weather and I have brand new ignition system.(opti, plugs, coil, wires)
Might want to have your starter tested.
Old Apr 4, 2004 | 12:53 PM
cridom's Avatar
sometimes in rain it just wont start but the starter is new.
im hopping is the opti or just a fuel filter.
Old Apr 4, 2004 | 12:59 PM
cridom's Avatar
plz help me.
Old Apr 4, 2004 | 01:45 PM
Daryn95Z's Avatar
I've got a new fuel filter too, but the same thing still happens.
You should try a new fuel filter (cheap/easy to change) and check the fuel pressure.
Old Apr 4, 2004 | 02:06 PM
cridom's Avatar
is there any brand i should get ot just go to advance auto parts and get 1?
also how can i check my fuel presure?
Old Apr 4, 2004 | 02:07 PM
Robs97Z28's Avatar
It sounds like you have an injector that is leaking.
It is let fuel to drain into 1 or more of the cylinders and flooding the engine. I would would put on a fuel pressure gauge turn the key on and watch the guage. It should read somewhere around 43 psi. Wait for the pump to shut off, then turn key off. Watch to see if the fuel pressure drops.
Old Apr 4, 2004 | 02:13 PM
cridom's Avatar
in that case is it easy to change injectors?
also if it is an injector what brand should i get?
Old Apr 4, 2004 | 02:26 PM
Robs97Z28's Avatar
lot of the guys I see in here are runnings SVO injectors, but most of their cars have alot of mods. I would run the stock size, other wise you will have to reprogram the ecm to run with the larger size injects. as of what brand, I'm not sure which brand to recommand. I hae had to replace any of mine yet. bosch, svo, or maybe accel. do not put use ls1 on a lt motor, becaause they are smaller injector do to the psi difference.
It also could be the fuel pressure regulator.
Old Apr 4, 2004 | 04:59 PM
cridom's Avatar
thanks.
could this just be the opti?
cuz i washed the engine not long ago
Old Jun 14, 2004 | 05:44 PM
93midnightta's Avatar
Originally posted by cridom
thanks.
could be....how hard did you spray water on the front of the block? does it only do it at startup or does it run good sometimes and then do it? when my opti went it looked fine when you scanned it but every once in a while the rpms would flutter really bad from about 2k-3k. if it only does it when you start it and then runs completely fine then it most likely has something to do with your computer being in opened/closed loops.
Old Jun 14, 2004 | 06:09 PM
elament's Avatar
Ruogh Start
I have read that the opti spark system for the 93-95 models had a flaw. When they get wet they run rough or not at all untill the system drys. The replacement opti spark systems have been fixed.
Old Jun 14, 2004 | 08:35 PM
Re: Ruogh Start
93-95 have unvented optis. they can buildup condensation in them and not run properly. some people have luck and they work after they dry out and others don't.
colts0455
Sep 11, 2015 06:16 PM
Jmj93z28
Jul 8, 2015 10:01 PM
BigTed187
Oct 7, 2003 03:34 PM
drewstealth
Jun 18, 2003 04:31 PM
ChoderBoy84CamaroZ28
3rd Gen / L98 Engine Tech
13
Mar 24, 2003 06:56 PM
