Help me get my harmonic balancer hub off
Old Sep 10, 2007 | 07:39 PM
chance94z's Avatar
I have tried everything I can think of and I I still cant get this damn thing off. Please, if you have any ideas let me know. This is on a 1994 z28. Thanks.
UPDATE!!!!!!!!!!!! I got it off!!!!!!!!!!!! WOOOOOOOHOOOOOOOO!!!!!!!
Old Sep 10, 2007 | 07:52 PM
speed_demon24's Avatar
How are you trying to get it off and with what puller?
Old Sep 10, 2007 | 07:53 PM
chance94z's Avatar
I am using a harmonic balancer pulley. I use a smaller bolt in the center of the hub and still nothing.
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
What have you tried? The balancer on my '94 came off rather easily with a small puller.
Old Sep 10, 2007 | 07:56 PM
BTC's Avatar
BTC
If you're pulling from the center, you're probably pulling against yourself. Did you remove only the 3 bolts that mount it to the hub.
Old Sep 10, 2007 | 07:57 PM
BTC's Avatar
BTC
http://shbox.com/1/pull_pulley.jpg
Old Sep 10, 2007 | 07:58 PM
chance94z's Avatar
I removed the center bolt also.
Old Sep 10, 2007 | 08:00 PM
chance94z's Avatar
In the picture it shows the pulley still on the hub? Do I leave it on there or take it off?
Old Sep 10, 2007 | 08:04 PM
BTC's Avatar
BTC
The three bolts are what mount the pulley to the hub. Put the center bolt back in. That's what your puller will be pushing against to get the balancer off. In the pic, shoebox has a socket over the center bolt to prevent damaging the head, but I don't think you need to really worry about that if you're careful. The hub will remain on the shaft. Do you want to take the hub off also?
Old Sep 10, 2007 | 08:06 PM
chance94z's Avatar
yes, I am trying to get to th timing chain.
Old Sep 10, 2007 | 08:07 PM
chance94z's Avatar
I got the pulley off, I am having problems with the hub.
Old Sep 10, 2007 | 08:08 PM
BTC's Avatar
BTC
You should also mark the balancer and the shaft so that you can install it exactly as it is mounted now. Otherwise, if you get the orientation off it could end up out of balance.
Danny McAdams's Avatar
Take the factory bolt to the hardware store, get a 3" long grade 8 bolt that matches your threads, screw it in crank at least 1/2", puller then should get hub off. Works for me!! Danny Mc
Old Sep 10, 2007 | 08:09 PM
BTC's Avatar
BTC
OK. I've never taken the hub off, so I can't help you there.
Old Sep 10, 2007 | 08:56 PM
Why did you start another thread?
http://64.65.63.61/forums/showthread.php?t=542171
