Help me find out if my timing is off
Old Dec 23, 2007 | 04:11 PM
95z28man's Avatar
I think I'm going to take off my driver side valve cover and look at the #1 cylinder valves as I hand rotate the engine to find out when I'm at #1 TDC. Can I do this? When exactly will it be at TDC? When intake valve begins to lift?
Another method mentioned to me was sticking a small screwdriver in the spark plug hole, but I'm not really comfortable doing that. If anyone has any other ways to check I'm all ears. I'm just trying to avoid taking off the crank hub and timing cover again unless I absolutely have to.
Right now I have waterpump, opti and pulley removed so I'm ready to go.
Old Dec 23, 2007 | 05:13 PM
Stl94LT1's Avatar
Put your finger over the spark plug hole, rotate the engine, when compression blows your finger away from the hole, you are close to TDC.
Old Dec 23, 2007 | 05:49 PM
You can look at the front of the cam and see where the cam is and also look at the crank snout to see if it is in phase.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
Brent94Z
Mar 21, 2002 04:44 PM
