help kertong identify this mystery part
help!
I found something interesting by accident today.
To the right of the PCM, where the a/c box is, there is an interesing black plastic piece that joins 3 vacuum lines together. What exactly is this, and what does it do? And where can I get a new one?
I've been battling a hissing under load, and poor performance. Turns out its a vacuum leak, I had zero vacuum since this valve was cracked in half.
I've put a vacuum cap on each of the 3 hoses - will this be ok to run it like this for the time being?
Thanks in advance for all help.
Vacuum check valve ? Dealer or auto parts store should have one.
thanks again, grip and shoebox.
Originally posted by mineralwater
Yes sir, that is exactly it! What does it do, anyway?
ChrisFrez
Nov 23, 2014 10:33 AM
Sixer-Bird
34
Aug 31, 2002 12:59 PM
