help intalling motor mounts.
Old Aug 19, 2003 | 01:57 PM
bunker's Avatar
Ok I read up some stuff from Brent's webpage & it says I have to do some welding?
Thanx guys, I'd like some step by step guides or something, I have the Energy Suspension ones.
Old Aug 19, 2003 | 08:23 PM
bunker's Avatar
TTT
Old Aug 20, 2003 | 12:23 AM
bunker's Avatar
TTT
Old Aug 20, 2003 | 08:20 AM
Ken95Z28's Avatar
No welding required. Just have to drill out the rivets on the old mounts and replace the old ones with the new ones.
When I had my motor out is when I replaced mine. As for installing them while in the car you must do one side at a time.
Hopefully someone else well chime in here.
Old Aug 20, 2003 | 08:40 AM
bunker's Avatar
K sounds cool, what goes in place of the rivet? Is it one of the bolts supplied? I have lots of bolts just wondering, also what are those zap straps for? thanx.
Old Aug 20, 2003 | 11:51 AM
Ken95Z28's Avatar
The driver side get the bolts in place of the drilling out of the rivets. The passenger side gets bolted directly to the K-Member so no bolts needed there except the stock ones.
This picture shows the mount already bolted to the K-Member
Passenger Side Motor Mount
Another Passenger Side View
Here is the view of the Driver Side, its hard to see but you can see a bolt in the mount.
Driver Side View
I did not use the Zip Tie, not to sure what's that used for.
Old Aug 20, 2003 | 03:52 PM
bunker's Avatar
thanx so much
alex5366
Mar 27, 2015 03:30 PM
Rde Bandit
Mar 21, 2015 10:17 PM
transam_388
Mar 15, 2015 11:53 AM
NewsBot
Dec 28, 2014 06:20 PM
