HELP! intake backfire and dead cylinders... No Bueno Baby
Old Oct 21, 2010 | 08:57 PM
nhill_05's Avatar
Mods in my sig are a little outdated. Writing this from my phone so please bear with me...
car is a 97 RS v6 auto that I swapped my 383 M6 into. I'm still using the stock RS gauges
and gauge wiring harness. I have had the car running perfect like this for a year now. I put
a 125 shot on a couple of months ago. I just changed my plugs to tr6s for the nitrous. Since
then my car has not been running right. It starts right up and it only has code 33 for map
sensor circuit high which can be caused by the unstable idle. I checked the primaries with
an infared thermometer and 4 6 and 8 stayed at about 115 to 120 degrees. All others were
about 275 to 300 degrees. I have changed all plugs again as well as wires and the opti cap
and rotor and distributor. No change. I put a known good coil and icm on to no avail. I feel like
I'm beating my head against a brick wall. I am going to check fuel pressure and the inj
circuits with a noid light.
Any other suggestions?
Thanks all!
Old Oct 21, 2010 | 09:01 PM
Drew24's Avatar
I would do a compression test to rule out head gasket. Do you specifically know its one dead cylinder and if so what cylinder is it?
Old Oct 21, 2010 | 09:26 PM
nhill_05's Avatar
Uh yeah..... 4 6 and 8. Like I stated in my first post. Good call on the compression test. Ill try that too.
Why would it blow a head gasket after changing plugs though?
That makes no sense to me. I don't know that they are completely dead yet. But they are the cylinders with
Issues
Old Oct 21, 2010 | 09:55 PM
Drew24's Avatar
Oops sorry i must have missed that but yeah to me if its that entire side of the motor points me to head gasket if your getting spark and fuel that is. But that strange that it happened after changing plugs.
Old Oct 21, 2010 | 10:02 PM
nhill_05's Avatar
I agree that it could be a blown head gasket... Im just perplexed about the timing of the problems. Literally all I did was change plugs... Problems ever since. Thats a good suggestion on the comp test. I'll try it and see what I get.
Old Oct 21, 2010 | 10:13 PM
Drew24's Avatar
Keep us posted
Old Oct 21, 2010 | 10:30 PM
nhill_05's Avatar
Will do. Thanks for the input!
ps. Updated my sig....
Old Oct 22, 2010 | 10:26 AM
speedracer2536's Avatar
y dont you try swapping plugs again.. if that was the problem.. maybe u got bunk plugs
Old Oct 23, 2010 | 05:50 AM
Guest47904's Avatar
Guest
Nitrous drives up cylinder pressure extremely high.....
Twice?? I highly doubt it.
Originally Posted by nhill_05
I put a 125 shot on a couple of months ago. I just changed my plugs to tr6s for the nitrous. Since then my car has not been running right.
Do a leak down test. I think you cracked a piston or 2 or 3. I see engines messed up from nitrous all the time. If it's a dry system, I'll bet money on it. If you ever fired up the nitrous below WOT I'll bet money on that too.
Old Oct 23, 2010 | 02:13 PM
nhill_05's Avatar
Its a wet kit and has been tuned for nitrous. I have forged internals and I have only sprayed it a couple of times. I was planning on taking it to the track so I changed plugs just for added safety. I had tr 55s before. And besides, if it was a cracked piston or two or three, I think I would have notice before changing plugs. A leak down test may still be in order though.
Old Oct 24, 2010 | 08:59 AM
Guest47904's Avatar
Guest
I put a 125 shot on a couple of months ago. I just changed my plugs to tr6s for the nitrous. Since then my car has not been running right. It starts right up and it only has code 33 for map sensor circuit high which can be caused by the unstable idle.
It was difficult to read that the problem occurred since you used nitrous or since you replaced the plugs.
We know you're smart enough to have NOT screwed up the plug wires on the same side of the opti?
http://shbox.com/1/opti.jpg
Since you then changed the entire ignition system. No way you could have duplicated the same error right?
So if we remember that all it takes is fuel, spark and compression to fire off a cylinder. You confirmed the spark portion is correct. Albeit the expensive way.
You need to confirm the injectors are spraying correctly. Doesn't matter if you have pressure or injector pulses. Could still be clogged.
So that leaves you with compression and leakdown.
Drtryder
Apr 22, 2015 04:17 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
95dzz28
Jan 12, 2015 05:58 PM
Snoman73
Nov 17, 2014 07:22 PM
Crazyj
Aug 20, 2002 12:04 AM
