Help identifying engine wiring harness
Old Nov 29, 2004 | 08:32 PM
Dfetter84's Avatar
Have a 95 motor, and 95 PCM and this harness
All the o2s are flat connectors, and I dont see any crank/cam position sensor plug (whatever the OBDII cars had to determine misfires) Which would leave me to beleive that its 94-95
The power to the O2 sensors comes from the brown wire, thats on pin F of the 10 way C100 connector (on shock tower)
The power to 1,7,4,6 injectors comes from the pink wire from the C105 connector, pin B The other 4 injectors gets its power from a pink wire on the C100 connector
The coil mates to a 95 coil
The reason Im asking is because 1,7,4,6 injectors are not receiving power, the harness is not plugged into anything (The C100 is however)
I know we could run power to those pins that dont have it, but I need to run power thru the fuse block - where to pick it up from? Im pretty sure its a 95 harness - but how should we power up the rest of this stuff?
cmdeshon
Jan 4, 2015 11:15 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
gh0st
Sep 1, 2002 10:24 AM
Teal94V-6
Aug 31, 2002 09:21 PM
