Help identify this noise
Old Jul 23, 2006 | 07:23 PM
97bowtie's Avatar
Ever since I put the LE2 heads on, I've had a strange noise coming from the passenger's side. I wouldn't describe the noise as metallic - it's more of a compressed air noise. I tried to get a video of the car idling, but the noise wasn't identifiable in the video.
With a timing light hooked up to the #4 cylinder plug wire, the noise and the timing light appeared to be in sequence. I swapped the lifters from side to side, and the noise stayed on the passenger side. I also have readjusted the rockers a few times, and the noise remains the same. The noise is very faint when the motor is cold, and gets louder as it warms up.
Any thoughts?
Old Jul 23, 2006 | 08:47 PM
Dave89IROC's Avatar
Re: Help identify this noise
loose spark plug? exhaust leak?
Old Jul 23, 2006 | 09:04 PM
97bowtie's Avatar
I tightened the plugs, and replaced the header gasket on the passenger's side. Noise is still there.
Old Jul 23, 2006 | 09:18 PM
ShowStopper540's Avatar
this may sound stupid seeing as its not happening anywhere else except the passenger side, but maybe the piston on one cylinder have hit, or be lightly tapping a valve?
Old Jul 23, 2006 | 11:33 PM
1racerdude's Avatar
Did ya check your P/V clearance?
The heads being milled or a change to a thinner gasket with the same or more lift they could hit.If ya went to larger valves that makes it worse yet even on just one cyl as the tolerances are not that close on a stock short block.
Ya can bet if ONE is hitting the REST are pretty CLOSE to hitting.
Old Jul 23, 2006 | 11:56 PM
HardcoreRM125's Avatar
Mine did this, and I found the noise comes from the injector. Kinda odd. I had them cleaned, noise is still there. On a scanner though, everything looks fine, even at WOT. Just a noisy injector for some reason?
Old Jul 24, 2006 | 04:29 PM
97bowtie's Avatar
Well, the noise isn't the injectors - I just tested them by unplugging them one cylinder at a time, and the noise is still there. The biggest clue to the noise may be the fact that I can't even hear it when the car is cold. After idling for 2-3 minutes, I can start to hear it, then after 5 or so minutes of running, it gets louder.
Old Aug 1, 2006 | 06:42 PM
97bowtie's Avatar
Anyone have any thoughts?
Old Aug 2, 2006 | 07:33 AM
vdubois's Avatar
possibly a bad valve seat. i dont think a head gasket would make that sound.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
