Help! How to take off wiper blades?
Old Jun 24, 2004 | 10:06 PM
luvmyz28's Avatar
Exclamation Help! How to take off wiper blades?
I am in the process of replacing a fender on my 93z and have to take off the wiper blades in order to take off the cowl grilles in order to access the fender bolts, etc. (according to the Haynes manual). I flipped open the plastic lids (both of which cracked... f*ck!) and removed the bolts that hold on the arms. But here I get lost because the arms do not want be lifted, screwed, or pryed off. How do I take them off? Anyone done this before? Thanks for your help-
Old Jun 24, 2004 | 10:11 PM
simple's Avatar
next to headers, the wipers have got to be the hardest thing to replace/remove/install on these cars i must've fought with mine for 2 hrs one day
Old Jun 24, 2004 | 10:13 PM
luvmyz28's Avatar
So how can I get them off without breaking them?
Old Jun 24, 2004 | 10:52 PM
wdz_lt1's Avatar
i just break mine...its easier to put on then take off
Old Jun 24, 2004 | 10:53 PM
wdz_lt1's Avatar
oh yeh..look in your owners manual
Old Jun 24, 2004 | 11:00 PM
97WS6SCharged's Avatar
Pull up on the blade slightly like you would to clean your windshield and then pull straight up on the point where it's attached to the car. The whole arm should come off fairly easily.
Old Jun 25, 2004 | 08:27 AM
Dave Holland's Avatar
Battery terminal puller.
-Dave
Old Jun 25, 2004 | 08:53 AM
-Dave
I suggested that once in the past, but have never tried it myself. Seems like it would work (and would be cheap).
Old Jun 25, 2004 | 10:44 AM
It does work, and works well. You just need to make sure you buy one of the small, cheap $3 ones so that it clears the hood. Better than prying at it and risking cracking the windshield.
-Dave
Old Jun 25, 2004 | 12:27 PM
-Dave
Good to know.
Old Jun 25, 2004 | 01:43 PM
luvmyz28's Avatar
Thanks, guys! I'm off to buy a battery puller.
Old Jun 25, 2004 | 02:08 PM
med_reject's Avatar
depress the clip with one hand and pull the wiper out with the other... its never that hard for me?
Old Jun 25, 2004 | 02:53 PM
I believe he is trying to remove the whole arm from the shaft of the wiper linkage.
Old Jun 25, 2004 | 03:51 PM
izzyz28's Avatar
I wish you could do it by hand! I used a small two-jawed puller, probably similar to the battery terminal puller you guys are talking about. My arms were on so tight we had to use a hose clamp around the puller to keep the jaws from slipping off. Major PITA. Just wait until you need to replace your wiper motor. By the way, does anyone know if you can get those rubber bushings for the motor assembly separately, or do you have to buy the whole thing? Mine is makeing a knocking noise again.
Old Jun 25, 2004 | 05:00 PM
luvmyz28's Avatar
Angry
Another question: Once I finally get these wiper arms off, how do I get them back on? The Chevy parts department told me that you just press it back on and then tighten the bolt. Does this make sense to those of you who have done this before? The only reason I am taking off the wiper arms is to replace the fender. Is there any easier way to do this? Thanks again,
