help here---Is my tranny?
Old Oct 4, 2003 | 12:20 AM
85LT1Z28MEX's Avatar
Unhappy help here---Is my tranny?
The car jumps really bad when going 1st to 2nd gear, but shifting manually don't. I re-programmed PCM with new wheels & tires size but still jumps.. is this the tranny ???
need help
Old Oct 4, 2003 | 12:34 AM
S.J.S.'s Avatar
Does it do it all the time???? Mine used to do that but only after like a long drive.
Old Oct 4, 2003 | 12:36 AM
Only at WOT,
Old Oct 4, 2003 | 01:15 AM
S.J.S.'s Avatar
How long have you had the car? Does it have a shift kit in it? Most shift kits are designed to shift hard at WOT.
Old Oct 4, 2003 | 01:21 AM
BRYAN programmed my PCM to shift hard. so it's supposed to do this jumpin' , or I have a traction problem?
Old Nov 3, 2003 | 01:00 PM
Ok.. It´s not a hit from a firmer shift.. What I meant is that when the car shift from 1st to 2nd.. start bouncing on the rear.. so I have to let the Gas pedal and then step on it again to stop the bouncing..
thanks..
Old Nov 3, 2003 | 01:33 PM
S.J.S.'s Avatar
"bouncing"???? What ? Do you mean wheel hop? Are you like WOT? If so then I would say you just have suspension problems and need to get some LCA's and relocal brackets.
Old Nov 3, 2003 | 02:19 PM
Joe Bellman's Avatar
If the back wheels are hopping check what S.J.S. said. Are the shocks original in the back, that could be contributing to the problem. If your tranny mount is broke, that will make the car feel like it is jumping up when the transmission slams into the bottom of the car.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
