Help Help Help
Old Mar 8, 2004 | 09:41 PM
silverdirtyZ's Avatar
Angry Help Help Help
Just Installed new heads and headers. I can not get the Battery to charge at all. Now my battery is completely dead. The alternator acts like it wont turn on. No output. My car wont run unless battery charger attached to it. Ran fine before I took it apart. Had computer reprogrammed to. Also installed crank under drive pulley. Please help alot of ahrd work and I cant even back it out of the garage. I know its gonna need a new battery but should the alternator try to turn on. Also no fuses blown.
Thanks,
Mark
Please help me.
Old Mar 8, 2004 | 10:01 PM
ANybody have any ideas
Old Mar 8, 2004 | 10:07 PM
Red96Lt1's Avatar
Some one will get to you. Don't bump yourself to the top unless your are stranded somewhere or it's been 24 hours.
Old Mar 9, 2004 | 01:03 AM
tryintogofast's Avatar
Is the electronic plug pluged in on the bottom of the alternator? This happened to me my alternator wasn't charging the battery until I plugged it back in.
Old Mar 9, 2004 | 05:44 AM
slopokrodrigez's Avatar
In addition to the alternator being hooked up, did you reconnect the grounds to the engine and frame?
