help harmonic balancer is vibrating
Old Apr 9, 2006 | 05:28 PM
bringBackCamaro's Avatar
the harmonic balancer is vibrating perpendicular to the way its spinning
probably by 1/4 inch
do I need a new harmnic balancer, or is it possible i bent something at the
drag strip
Please help
Old Apr 9, 2006 | 05:35 PM
I8ASaleen's Avatar
Re: help harmonic balancer is vibrating
Yes you will need a new balancer b/c most likely the rubber between the outside track and the pulley has been worn out. However I haven't found a kit to remove the hub b/c the ones at parts stores don't have the proper bolts. I tried a 6" 3-jaw puller, but I can't seem to fit it between the spokes.
Old Apr 9, 2006 | 07:16 PM
aboatguy's Avatar
I agree your balancer has failed.
I have pulled three LT1 hubs using a plain old Sears Craftsman Harmonic Balancer puller. I went to ACE and I bought a set of bolts/and washers that I place through the puller and tighten into the hub. I have a 1/4 drive extension that I place into the crank and the hubs have come right out with no drama. (The hole in the hub is too small for a puller to fit through hence the extension).
Old Apr 9, 2006 | 09:10 PM
robyrd's Avatar
Go ahead and replace it because in the next few drives it will eat you belt. I hate when i can talk from experience
Old Apr 9, 2006 | 09:41 PM
what brand/type did you choose to replace your OE one?
Gm part#12551138 is about 180 at gmpartsdirect
ORiley and Autozone have DORMAN lt1 balancer for $65
Oriley and Autozone can special order PIONEER lt1 balancers for around $67
If I use a stock balancer, do I need to replace the hub too?
Old Apr 9, 2006 | 10:19 PM
LT4orbust's Avatar
hub does not need replaced
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
